Oxygen sensors ~ interpreting readings
When driving and coasting in neutral, the bank 1 / 1 sensor fluctuates between low & high readings on the Ultragauge, whereas the bank 1 / 2 sensor goes to low readings and stays there.
Is this normal, or is the bank 1 / 1 sensor going bad?
