Originally Posted by BabyDiesel
I would not say this, but that it is highly likely that the Cd is greater than 0.28. If you can perform coastdown testing over Instructables.com, then we could find out for sure and settle this
The C's Cd 0.28 would match the Mitsu Mirage, and they look similar IMO
As someone who owns/driven both I am pretty sure Mirage has better Cd, that's why C Cd is suspect.
Playing with calculator shows that changing Cd in 0.28-0.31 with engine efficiency to match observed MPG at 60-65 MPH doesn't change expected ~42 at 70-75. So it looks like engine might have been optimized for lower RPMs and at higher RPMs it is less efficient.
