Old 11-30-2015, 08:36 PM   #5 (permalink)
cmyers
I read that when grid charging to monitor the voltage and when it starts to drop then the charger should be removed. Usually that would happen after 2 or 3 hours of charging. A few times the current LED shut off meaning that current isn't flowing to charge the battery. I usually charge the battery at night or when it is colder outside. Haven't really figured out how or where to install a fan when charging. I did have a hair dryer hose stuffed into the fan boot and ran that on cold when charging during the day. The Civics have a computer controlled fan and I haven't found anything on how to run it when charging. Thanks for your help.
