Originally Posted by e*clipse
I think the smaller motors in the Prius transmissions would make excellent bike motors.
with mg1, etc, it is a bit wide. Even the mgr is a bit wide, and I would need a radial load bearing on the output, or a very solid through axle, or something.
Though I am very interested in what a realistic cnc job (pre-designed) case would cost, for say side by side mg2 stators/rotors. Or something to hold an mg2 up to the rest of my gs gearbox, somehow, even though I might never take it out of first (or just use some of the gears therein as you suggest).
Also, is there a story on cooling the mgr? That might be a major difference between this and 123kw. freebeard said something about korea?!?
re two speed, the input shaft as output occurred to me too, you can use a little bit of power to hold mg1 steady and mg2 will be reduced by .72, which is probably a useful step in an EV, or drive mg1 and mg2 together for full speed. It probably isn't worth it, I'd just weld the planetary with mg1 and 2 in phase and power them as a parallel unit if possible, and take advantage of the downstream gear reductions.
The standard stuff I removed from my car was really heavy (more than 2 MGR's) and the cost of a similar gearbox
I hear ya, I'm looking at a gl1800 box right now and wondering what I was thinking. It's junkyard style, but there are high performance bits (and vehicles) out there that are already put together if you don't need a hobby and have the cash. The challenge really is to leverage the surplus bits.
For instance replace the Prius gas engine with a VW transaxle.
meh, I'd rather overpower/gear it enough to not need a transmission. besides the vw trans is crappy, ever get one stuck in reverse and 3rd?
In case anyone hasn't seen it
nice machine, would love to understand the costs. But wow is he pumped over a golf cart
outsourcing machining has been miss-or-miss for me so far, I'm gonna start dremelling my own splines soon at this rate
