Originally Posted by 2000mc
4000rpm?
Is that holding the throttle open? Or just spraying at closed throttle?
Some vehicles seem to not always cycle the fuel pump when the key is repeatedly cycled, if you take the key out for 5minutes, does it reliably turn on the fuel pump the first time the key is turned on?
Today I will do a video of if the throttle cable is stretched too tight.. it may be.
