Old 12-01-2015, 06:53 AM   #11 (permalink)
GearheadTool
Originally Posted by Cd View Post
I had a similar problem. It turned out to be the ECU.
When you turn the key to the second click, ( just before the starter kicks in ) do you hear a slight whirring noise ? ( it lasts for around 3-4 seconds )
This would be the fuel pump priming.
If the fuel pump is priming, then I would look at the ECU.
Good luck
I will check this today.
It primes so intermittently..
