Here is one lifter I modified out of my Beetle.
I noticed #4 was always a little hotter with a doghouse shroud with all of the stock tin installed. The shroud heater ducts are also welded shut. I ran 312*F head temps with an Engle W130 cam and CB turbo EFI. I did have oil light flicker at hot idle and a Melling 30mm oil pump. I don't know if that mod had anything to do with it. That was with Mobil 1 turbo diesel truck oil or Bradd Penn oil. Seemed to run better at 9:1 compression over 8:1. I wanted to try the coating on the pistons but some DIYs had some flaking if I remember correctly.
