Old 12-02-2015, 02:14 PM   #7089 (permalink)
Piotrsko
VOLT packs can be up to 398 v if you dont mind being risky at 4.145 a cell. Gives you 2.5 ish more KWH. On my ranger split pack I'm running 197 volts for 394 total last two years.
Imho even with 600v components thar be huge spikes that might fry capacitors. Sol1 controller are built that way but delimited to 340 as safety measure. Kinda pissy using volt packs......
I have seen the 500 vdc meter peg while the field collapses on abrupt off throttle overspeed. Don't know by how much overpeg, but.........
jedsmd (12-09-2015)
