Originally Posted by Old Mechanic
fuse, power to the pump (read at the pump itself), relay energization circuit (need a wiring diagram).
bad relay
bad pump
bad ignition switch
bad ground
wiring defect in the circuit
no gas
fuel tank pickup damaged or bent where it will not pick up fuel
regards
mech
looks like I pegged it.
bad ground
no gas
still don't understand your response to that post but glad to see you got it running
regards
mech
