Originally Posted by aerohead
Since streamlined bodies don't produce lift there's no good reason to design in downforce unless you're going to race the vehicle.
But tires cause lift, so maybe a little downforce to counteract that might be a good idea
Just a little bit done via a flat underbody, since a car is already relatively close to the ground you might as well.
My car definitely "drifts" a little at higher speed on the freeway. Headwind makes that happen too. Less of that would be nice to have.
