Old 12-03-2015, 12:22 AM   #35 (permalink)
oil pan 4
I am thinking take this:
And modify to this:
I will be putting the rectifiers out side of the housing, outside of the hood where they can stay cool since these schottky diodes are only rated to 125'C and things that alternators are typically made of are rated up to 200'C.
Silicon diodes are good at elevated temperatures.
VR is where I can fine tune the voltage at the battery with the Vsense wire.
Vsense is for use with the LiFePO4 and power inverter setup, to provide boosted voltage level at point of generation to provide proper voltage to the battery during heavy inverter use.
The switch labeled swF kills power to the exciter field.
In the stator I will utilize the 4 wire wye configuration.
ID:	19207   Click image for larger version
