Originally Posted by Piwoslaw
Unless you can find your engine's BSFC, then the rule of thumb is to keep load around 80% and the RPMs in the highest torque range. Then coast...
Originally Posted by ConnClark
Diesel's usually get their best efficiency at their peak torque. Find that out and you have won half the battle. Sometimes you can find a BSFC map for your engine. That can give insight on how you want to accelerate.
If you have a turbo charger on a diesel install a boost gauge. Driving in a manner that keeps boost low shows you are driving efficiently (DO NOT MODIFY YOUR CAR TO LOWER BOOST).
I have tried a lot to find a BSFC map but without any luck. I have found a dyno run though which shows the torque starts coming at about 1800 rpm and rises until it reaches peak torque at 2600. However, I would assume that peak torque comes with high boost. To complicate manners a bit, my car has an eco button that remaps the engine for higher efficiency by reducing throttle response and torque by 10%. Should I drive with the reduced torque map or is it more inefficient?
