Originally Posted by TT-Man
By separating the windings full battery voltage may be applied to each, but would need a 12 diode bridge
if you can seperate them, you can re-join them in delta and get the same thing with a standard 6 switch inverter.
I did some brief analysis of a 12 switch, and there isn't any difference (except more complicated), with three phases in delta you can see full voltage swing across each field (sinewave assumed)
