Things To Do:
- AC Delete
- Kill switch
- Fill in missing fog lights
- Partial Kammback(sp?)
- Experiment with rear slipstream
- Grille block
- Belly pan
- Coilovers and wheel spacers to narrow gap
- Routine maintenance
- Mirror delete
- EOC toggle
- Remove rear wiper
- Front plate relocation
- Wheel covers
- Narrower tire
- LED headlights
- Learn to pulse drive with EOC
- Disable Power steering
Done:- (Done)Replace clutch
- (Done)Disable daylight running lights
- (Done)Replace MAF Sensor
- (Done)Replace Engine Coolant Sensor
- (Done)Taller tire
- (Done)OBD2 Bluetooth device install to watch MPG/engine
- (Done - Partially)Antenna Delete
