Old 12-06-2015, 10:26 AM   #11 (permalink)
DragBean
PizzaRimBoy
You haven't even talked about engine mods. If you can find a charging location at work, you could easily get one deep cycle battery and pull the belt (and field wire) on your alternator. That will give you at least 5% mpg probably 10% gains. Two batterries will get you the 80 miles there and 80 miles back.
