Old 12-07-2015, 08:24 PM   #6 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 37.93 mpg (US)
That honey color, even in new oil, is dirt. Clean oil is transparent. I once designed a hydraulic system and specified a three micron absolute, full flow, no bypass, high collapse element. After running 18 months without an oil change, the analysis said the oil was good for continued service. When I looked in the reservoir, I could see the bottom through about 20 inches of perfectly clear transparent oil. That's why oil added to industrial hydraulic systems, even from a new container, is supposed to pumped in through a filter.
Motor oil has additives to counteract acids from blowby. Those additives get used up.
If you had an engine with really good filtering, analyzed the oil regularly, and added additives as needed, you could run the same oil forever. It's cheaper to just change the oil, though.
The Following User Says Thank You to JRMichler For This Useful Post:
Cd (12-07-2015)
