I see mention of one spec, but there are three you need to consider/match
Bolt pattern you know about, the 4x100mm, and that's foolproof.
Center bore, the center hole in the wheel must match the hub or you can't balance it. Spacers get lost. Get this right.
Offset, be sure to get FWD wheels, high positive offset, if you like your drivetrain to work.
HAve fun,
Frank
