Old 12-11-2015, 02:13 AM   #9 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by fbov View Post
I see mention of one spec, but there are three you need to consider/match
Bolt pattern you know about, the 4x100mm, and that's foolproof.
Center bore, the center hole in the wheel must match the hub or you can't balance it. Spacers get lost. Get this right.
Offset, be sure to get FWD wheels, high positive offset, if you like your drivetrain to work.
HAve fun,
Frank
Another concern is the lug nuts when using different wheels. Honda and VW use a ball seat and Toyota uses a tapered seat. Honda lug nuts will fit Toyota studs.
Is the center bore really an issue? I just put Subaru wheels with larger center bores on my mother's Prius for the Winter. Seems fine so far with the lug nuts centering the wheels. And I look forward to the wheels not getting stuck to the hubs over the Winter!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
