Thread: The DragBean
Old 12-12-2015, 12:42 AM   #16 (permalink)
DragBean
PizzaRimBoy
@freebeard
I replaced the #8 screws with 1/8"x3/4" self-tapping screws with 3/8 hex heads and rubber washers.
The pizza tray saved the rim for getted scouged up, although the rim got a little bit where the concrete impacted it.
And yes the concrete was from the road, it got dislodged and sent up by the semi. The curved redwood cut a chunk tore out right on the edge where the wood curves the most. I'll probably have to figure out how to separate the fiberglass from the existing wood and re-do it. Or I might be able to backplate it and fiberglass it.
@CD How do you recommend I deal with the back? I'm going to put side squirts on, but I'm at a loss as to figure out the back. Maybe a little Nascar thing on the trunk?
The Following User Says Thank You to DragBean For This Useful Post:
freebeard (12-12-2015)
