Old 12-12-2015, 05:31 AM   #12 (permalink)
dfeldt91
Mazda 3 - '06 Mazda 3 iTouring
I have 14" stock wheels and just bought a set of 15" wheels. Both are wrapped with 195/60 tires for a 1" diameter increase which equates to a 4.1% decrease in RPMs. I get lug bolts Monday so I'm hoping that the larger size will give me a slight increase in fuel economy.
If you drive in your torque band then the size increase shouldn't cause any consequences except less fuel being used. Any larger of a tire and it will probably have a negative impact especially when outside the torque band. A narrower tire will give less resistance and a little better fuel efficiency which might come in handy with the larger wheel and tire size.
