Old 12-12-2015, 01:59 PM   #14 (permalink)
dfeldt91
Mazda 3 - '06 Mazda 3 iTouring
Darn, that is quite high. In my Golf MK3 with stock 195/60/14's I am at 3000 at 75 and about 2400 at 55 with it increasing 200 RPM per 5 MPH higher.
I'm looking forward to my 195/60/15's to lower that.
I think you will quickly see problems with a four inch larger tire. When turning the tire will more than likely rub the wells. I put 33 inch tires on my car that had 28 inch tires stock and it rubbed bad! Looked cool though! LOL
I am going up one inch in diameter with my swap and might even push it another half inch or so larger when I get new tires. That is about as large as I could go without narrower tires since it will start to rub when turning if any larger.
