Originally Posted by MPaulHolmes
Also, if you type "save" it will save the settings I hope. I haven't checked that it properly saves and loads everything with all the new settings available. So, hopefully you only have to set up the throttle once and then never again.
The save command does not appear to work. I get the 'PC Load Letter' error
