Old 12-14-2015, 12:25 PM   #10 (permalink)
oil pan 4
I was digging around in my electronics stash and found a DC to DC voltage booster. I had forgotten about these.
According to the Meziere manual their pumps can be used on 16 volt systems.
So I wired the voltage booster to the pump and turned it up to 16 volts. The pump ran real hard drawing 10 amps.
I figure I could use this in the summer when its real hot out and the coolant temperature starts to get too high when towing or something.
So the operational voltage range will be between 6 and 16 volts, favoring the lower range during the cooler months and during warm up.
