Old 12-15-2015, 07:34 AM   #78 (permalink)
ev99saturn
ev99saturn's Avatar
Snake Oil - '10 Factory Five Racing Mk4
90 day: 77 mpg (US)
Clear grill block
I used 1/4" acrylic sheet to block off 4 openings in the front of my car, and also added the air dam. The large oval opening, referred to as the 'parachute' by a friend seems like it should be making a difference although I haven't measured any economy change. The sheets are attached by either rivets, or epoxy on the 3 smaller ones. Also blocked off the side louvers.
The car is electric so airflow for cooling is not necessary. A small radiator can be seen in the front, which is for motor controller cooling.
Wayne
The Following User Says Thank You to ev99saturn For This Useful Post:
Istas (12-15-2015)
