Old 12-16-2015, 02:22 PM   #7099 (permalink)
Piotrsko
Most people use a tranny cooler which can be had fairly cheap at discount auto parts places. Salvage pc fan or two, violah. Or if your into car bling..... some all in one kits for $$$$$$
You can go convective or buy a $10.00 fleabay pump. About $10 for a windshield washer tank & pump at pick n pull. I like drip systems for plumbing bits.
Reservoir isnt necessarily used if the cooler is not leaking and you purge system of air bubbles.
5050 premix of whatever coolant you have around as most have additives for aluminum components anymore. Hard to get an iron block today.
Bela (12-16-2015)
