Put 4 new 205-60-16 on the Altima Saturday morning using 4 oz of counteract balance beads, and filtered valve cores. Cores and beads cheaper on ebay than local. Cores about $2 each, beads $20 per lb. 2 tires already had beads so reused those.
I've had beads get stuck in the valve core a couple times and only way to clear is to remove/replace core. Shouldn't be a problem with the filtered cores.
HF tool just like mine, I need to pickup some new drop in anchors before next tire change.
