I always wanted a grease pit that had a hinged ladder at one end and when you lift it up these an entrance to a Secret Tunnel system.
At the recyclers today I got a nantenna for $6.40 that has 10ea 4ft pieces of aluminum tubing between 7/16ths and 9/8ths inch diameter. I'm planing on a tubing frame with luan plywood fill panels. Can you describe the wheel hold-down system?
Originally Posted by permalink #22
*I've already widened the body to accommodate a 42-inch front track to fit the front load cell support troughs.
At permalink #24 the track is given as 24.4 inches.
Can they accommodate a tricycle?
