Old 12-17-2015, 02:33 PM   #9 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
No instrumentation other than the odometer and gas gauge! I get 70+ MPG by coasting and going slow. I cruise at about 45 MPH with the engine spinning at about 1300 RPM.
The grill block is made from the bedliner of a pickup truck. Anything will work, but I like the look and it's virtually indestructible. I just cut two pieces to fit and used stainless steel screws to hold it in place. The center of the grill is open and I use the license plate to cover that. I have multiple screw holes for the plate and I move it based on ambient temps.
ID:	19306   Click image for larger version
ID:	19307   Click image for larger version
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
j12piprius (01-04-2016)
