Old 12-17-2015, 06:03 PM   #6 (permalink)
aerohead
or does
Originally Posted by Tulok View Post
Does the grill block have to be on the outside of the body, or does merely blocking off the actual radiator serve the same function?
If the block is done flush with the body,you've bought some distance from the radiator face which can be turned into an airtight,diverging duct,as Chrysler did with their Daytona Charger.
It's this ducting which allows the opening to be only 1/6th the radiator height if it's depth is equal to the radiator height.
