Old 12-18-2015, 08:30 AM   #136 (permalink)
user removed
Lots of times the shaft play allows the vanes to contact the side of the housing, where clearance needs to be minimum and shaft wobble is a killer. Make sure the supply and return oil lines are not clogged with carbon.
regards
mech
TimV (12-18-2015)
