Old 12-18-2015, 06:12 PM   #21 (permalink)
aerohead
visor
Check out this thread for a similar discussion.
http://ecomodder.com/forum/showthrea...ure-33061.html
The visor helps block unwanted sun in the driver's eye.It also reduces solar gain a bit which helps on AC load.
If your determined to have one,give it some leading edge radii to help with attached flow.
Here's one in the tunnel
BamZipPow (12-18-2015)
