I wouldn't normally expect a larger manifold to help low end, but would have been hopeful about the spacer. The dynos are a disappointment though, starting at 3500rpm for the larger manifold, and 2900 for the spacer, doesn't really give you insights into low end/ cruising behavior. If they were going to help low end I would think they would try to showcase that
