Old 12-20-2015, 07:02 AM   #3 (permalink)
Davo53209@yahoo.com
Originally Posted by Ryland View Post
I would guess the valve cover gasket, they age and shrink.
They should come with new seals for around the valve cover bolts too.
I probably should have mentioned that I replaced the valve cover gasket and seals that following spring. I was fortunate enough to catch in time when I'd noticed that the spark plug wells were filled with oil. To add further, I used Honda bond in the process and torque down the bolts to 10/lbs.
No, I'm thinking that I may have another problem.
