Old 12-20-2015, 03:20 PM   #139 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by ByDesign View Post
but it's my toes that get the worst.
I've used booties over my shoes. But the real problem is the metal cleat connected to a metal pedal and to a metal connector right next to the foot that acts as a heat sink to suck the heat right out of the foot.
I've found shoe inserts for winter - felt with alu foil on the top side - keep the underside of my foot warm, but remember to loosen the shoelace or else you will not have enough circulation. For the winter I switch my SPD's to normal pedals, then cut a plastic bag to cover the toe-clip. This blocks the wind and the water splash. When it gets a few degrees below freezing I put on heavy-duty booties (Showers Pass), but even these with warm socks don't keep my toes from freezing when it's below -5C
