Did I miss something for the 3 wire IAC valves? 23.4 States "The 3-wire IAC valve is covered at the end to this section." but I don't see how to test it or any info for it. I'm working on a 2003 Honda Element and just want to make sure it works or not (i.e. ohm/voltage reading on which pin). I did see in another post that the 3 pin is like the two pin plus the 3rd wire acts as the spring. I do have the manual for the car but it just states to do a IACV test on the Honda brand OBD II sensor and I just have an off brand one.
