It's been over a month since I discharged & grid charged the two Insights, and neither car has had a recal since. I have been using assist a lot more than I used to, and the battery has been handling it very well. So far, so good!
I pulled off the moon discs and aired up the tires this weekend for the first time since August. When I checked them before airing them up, the lowest was at 49 psi and the highest was at 52 psi, that's not too bad considering it had been about four months since I aired them up last, and they all lost air at about the same rate.
After the holidays I'm going to swap out the tires for the new set of RE92s I recently bought.
