Old 12-23-2015, 06:45 AM   #11 (permalink)
cRiPpLe_rOoStEr
Originally Posted by stiletto2 View Post
That one tire went 35,000 miles with some of those miles banked over scraping hard parts in the twisties. It manages to navigate corners just fine... it just does it differently than a bike tire with its round profile. Bike tire in a lean effectively has a smaller diameter so its like a coffee cup on its side that will follow an arc when rolling. Car tire effectively gets that smaller diameter by compression & flexing of the sidewall along with some of the tread face. Different method, same result; tire follows an arc. Car tire tread does flex and will lie flat on the road surface where it makes contact. It does not ride on a hard immovable, non-pliable edge.
You might say whatever you want, I'd not feel comfortable with a car tyre in a motorcycle (unless it has a side-car ).
