Old 12-24-2015, 07:37 AM   #25 (permalink)
DragBean
PizzaRimBoy
Getting Rid Of Weight
So to all the neigh sayers, OK maybe 10-20 pounds of weight isn't worth the extra road side hassle of an extra 30 minutes (assuming your are proficient at putting [& Removing a tire *THis is probably Harder 'MOre Technieque'*] and removing), Then
OK,
But if you are on a weight reduction campaign
(Which includes cutting off double slices of peacon pie)
Then this could be worth it.
Especially if you can get rid of 100 Lbs of dead load.
Overall I think it is something to consider if you Have The Skilzs (and don't want to be stranded lower case).
