I got to raise the front end up still and make sure the tires don't have a jacked up sway (as in I jacked the car p and free spun the wheel and could see a visible sway).
Both reaer ends had this, 1/8 to 1/2 lateral sway result in significant vibes at 60 yo 75 mph. And the tires were abnormally hot upon just checking.
So i'm thinking if I fix everything I should achieve record mpgs with the DragBean (especially since the new tires were Noise reducing and narrower width).
