@oldtamiphylle
Tha'ts a good idea. It sounds like i might be able to put fender washer spaces to compensate.
Or do you think everything could warp back into place?
It's defintely robbing MPG - I can feel that tires' are hotter the normal when I get done.
I did pick up $10 wheels that I pre-spun to check for any visible deflections and didn't see any. Once I mounted them on the hubs (one had a visible deflection), both the back tires had visible side to side deflections when I spun them up jacked off the ground. (I noticed this midway between a 800 mile trip). I kept on stopping to mix and isolate wheels and to take off the pizzaboy rims.
Seems like the warp may be contagious to nearby associated parts...
Reason: Almost 1000 miles of driving
