Thread: Warped Hubs
Old 12-24-2015, 01:50 PM   #6 (permalink)
freebeard
Front Macpherson strut? Semi-floating rear axle? Something inbetween?
With a dial indicator or equivalent, you could measure the run-out on the hub itself, axial and radial. Washers are probably not the answer, you'd need washers with a minimum of two different thicknesses to shim it. (Assumes five lugs, two unwashered, one the correct thickness and two about 0.6215 of that)
Tighten the lug nuts progressively, in a star pattern.
