Thread: Warped Hubs
Old 12-24-2015, 05:47 PM   #7 (permalink)
RedDevil
90 day: 55.8 mpg (US)
It is not just like something got in between the hub and the wheel?
When you put the wheel on the hub it should feel like it seats firmly, not wobbly.
Obviously the wheels should rest on the bed, not the axle cap or whatever.
Is the tire seated properly? If not the rim runs straight and the sway is in the tire. Or maybe the rims were damaged after all.
If it is the hubs you should be able to see the warp and possibly the damage on them without the wheel. Inspecting them closely may be a good idea.
(Sorry if you already thought of all this, hope it helps if you didn't...)
Best of luck, hope it is an easy fix. And +1 on the higher fuel consumption in the first 2000 km on a new set of tires. You may need a higher tire pressure to compensate for the narrower track anyway.
