The problem I would see is that the mpguino has no way of measuring manifold air pressure. MAP dictates the pressure at which the fuel is delivered and therefore the volume delivered per pulsewidth. On a motorcycle you will tend to vary the throttle/MAP and gear selection more than with a car in general in city use. Not saying that it won't work but given the small fuel volume of fuel and greater variance of engine operating speeds, the result will not be reliable or often repeatable. A fuel fill-up log dealing with the 3 or so gallons every 120-200 miles will be far more accurate. I'd recommend the fuelly app.
