Old 12-29-2015, 08:32 PM   #33 (permalink)
1hondaman
Rob
1hondaman's Avatar
Silver Bullet - '00 Honda Civic HX
O-2 Sensor add-on in HX
When my car is in LB the commanded AFR's from the ECU seems to stay ~20.5.
When not in LB the commanded AFR is ~14.6
FIREHAWK618 Where did you plumb in the O-2 Sensor to get your AFR readings ? Did you weld in a "bung" at the upstream side of the cat in the exhaust manifold ? Did you find a crack in your exhaust manifold ?
