From a marketing standpoint, I would adhere to K.I.S.S.
Keep it simple stupid
You have alot of info there and many will see it as they drive by. So consider a message that says;
Original MPG 28
Current MPG 40
How
Ecomodder.com
Because if you don't keep it simple, the minds of our simple friends will simply look past without a seconds thought. Just my 2 cents, I applaud the effort, I will be going that route soon too.
I recently discovered a vinyl material that is dry erasable so I can continuously update my numbers.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
