Old 12-30-2015, 07:52 PM   #2 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Not only that, but it can restart your engine even while its being shut off. In a normal vehicle, this would normally cause some pretty nasty noises to occur as the starter pinion attempts to mesh with the flywheel.
If the engine is above X rpm, it doesn't need the starter to restart, just the ignition - If you EOC you'll sometimes key back on at around 250rpm and the engine will re-fire. I'm guessing there's a window between around 250 and 0 rpm where the ECU waits for a 'zero' RPM signal before engaging the starter. There are also extra sensors on the flywheel to help the ECU synch up sooner at part crank revolutions.
I have two factory S/S cars and their literature only speaks of 'reinforced' ring gears, special batteries and larger starter motors. They're still brushed DC.
The sales brochure of the Renault speaks of 'programmable' stop/start. The owners manual makes no mention - it will be interesting to see what that means when the factory ordered vehicle actually gets here in two months.
