Old 01-01-2016, 01:19 PM   #15 (permalink)
Zach
Zach's Avatar
Veloster - '12 Hyunda Veloster Base
90 day: 40.66 mpg (US)
Thank you so much for the detailed replies and explanations! I have been reading about the apps/OBD2 connectors and I think it would be good option for me right now and if it doesn't work out I will look into investing into the ultragauge.
I actually looked at your build thread and like the way yours looks! I will see about doing something similar to mine. The only issue I might run into is scraping on my driveway because I have a bump right in the beginning but I guess I can try and see. And it looks to be easier that trying an under-belly pan.
Do you think an upper grill block would be worth trying or should I stick to a behind the grill lower block? I tried to show what it would look like in the previous posts, right now my air intake (OEM) scoop pulls air from the upper grill block and the opening isn't very large.
