Originally Posted by Zach
Once again awesome tips! I think I will start experimenting with a lower grill block this weekend with cardboard since I have some from Christmas. Definitely going to look into some threads here on the best final product though.
I checked my psi and each are sitting at 30. Max sidewall is 50. Was thinking of going to around 40-45. Anyone have experience with a tire inflator? Shop Kobalt 12-Volt Power Source Air Inflator at Lowe's
Depends what your tpms system is set to. Mine won't give an error light until 51 psig but if the stock tire size is 44 psi max then it will come on much sooner. Set it 10% below sidewall max so there is room for pressure increase when the tires get warm. I have mine set 38 front 45 rear to help with handling characteristics.
