Old 01-04-2016, 03:14 PM   #10 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by bobdbilder View Post
I realized newer cars have only one fan, typically the engine radiator fan. There is no dedicated fan for the aircond. I think the fan is switched on by both condition; hot coolant or aircond control.
The savings is both in reduction of electrical load and minimal savings in weight due to deletion of one fan.
My P307 has A/C (the condenser is right in front of the radiator) and only 1 fan. The fan kicks in when the coolant temperature reaches 98C. If A/C is active, then the fan keeps coolant temperature below 82C, which is a bummer if you are trying to keep the engine running hot for FE.
Ideal would be if the A/C condenser and radiator were independent (not in front of each other, but side-by-side and walled off), with their own openable grille blocks and fans. But then you have the weight penalty and the circle closes.
