Originally the car would start vibrating enough to start shaking my rearview mirror significantly
This is what I call "significant" shake.
That little bit of run out your reading is nothing to worry about.
It sounds more like a tire problem.
Are you sure that you don't have a tire that is separating ?
A tire that is separating will cause all sorts of problems like you are describing.
It's possible that a tire was injured in your accident.
This can also happen as the tire is nearing the end of it's life, one or more steel belts can shift.
Check all the tires carefully.
